2 weeks ago
This month, check out the SQL Transformations course from Workato Academy! See how SQL Transformations give you the power to enrich, manipulate, and transform data seamlessly within your Workato recipes, while optimizing workflows, reducing repetitive tasks, and taking your business automation to the next level.
Learn to leverage SQL queries and execute sophisticated data transformations directly on your recipe data with Workato Academy's SQL Transformations course! Master techniques to filter, join, aggregate, and reorganize data from diverse sources within your automation flow. SQL Transformations enables you to tackle complex datasets, carry out calculations, and format data perfectly for downstream systems, enhancing both the versatility and strength of your recipes.
This course is perfect for:
And anyone looking to make their workflows more intelligent and efficient!
If youโve completed this course or are interested in taking it, let us know if you have any questions or comments!
Weโd love to learn more about your experience with SQL Transformations using Workato. How has this course inspired you to take charge of SQL Transformations within this course? What are your biggest learnings or what surprised you the most?
๐ We will be randomly choosing one comment on this post to win exclusive Workato swag! Donโt miss your chance, share your thoughts or questions below!
Your feedback and stories help others get the most out of Workato Academy and inspire new ways to automate!
Read more:
Letโs get the discussion started! ๐
2 weeks ago
Hi @dianest ,
Thankyou for sharing these monthly deep-dives on new Workato features, itโs a great initiative and truly helpful for the community.
Regarding SQL Transformations in Workato, here are some key highlights based on my experience:
A powerful ETL/ELT engine โ๏ธ
Enables seamless transformation of bulk datasets directly within Workato recipes without relying on external databases.
No storage limitations ๐ฆโจ
Since SQL Transformations run fully in-memory, you are not constrained by traditional database storage restrictions.
Support for file-based data ๐๐
A unique capability to include files (CSV, Excel, etc.) as part of rows during transformations, an excellent add-on feature.
Advanced data cleansing & quality operations ๐งน๐
Ability to filter, cleanse, deduplicate, validate, and normalize large datasets efficiently. You can also remove or transform specific fields as needed.
Connect multiple data sources effortlessly ๐๐
Supports combining data from Workato Data Tables, Workato FileStorage, Content Streams, and various app connectors.
Join & compare cross-source data ๐๐
Ability to join or compare datasets from different sources, for example, matching FileStorage data with Data Tables, all within a single SQL query.
Improves recipe and task efficiency ๐๐
Offloading complex logic into SQL Transformations helps optimize recipes, reduce task consumption, and simplify overall workflows.
Easy Excel โ CSV conversions ๐๐๐
SQL Transformations makes it very simple to convert Excel files to CSV and vice-versa, something that is more complex when using only native Workato actions.
Overall, SQL Transformations is one of the most powerful additions to the Workato platform for heavy data processing and cross-system data preparation.
Thanks & Regards,
J Rajesh Kumar.
2 weeks ago
Hi @dianest ,
Thanks for sharing.
SQL Transformations has quickly become one of the most impactful features in Workato for handling large-scale and complex data operations. It brings true SQL power directly into recipes, eliminating the need for external databases or heavy scripting.
1๏ธโฃ In-Memory ETL/ELT Engine
Run complex transformations on large datasets directly inside Workato โ no external infrastructure required.
2๏ธโฃ No Storage Limitations
Since everything runs in-memory, youโre not restricted by traditional database storage constraints.
3๏ธโฃ Multi-source Data Handling
Easily combine data from:
Data Tables
FileStorage
Content Streams
App connectors (Salesforce, SAP, NetSuite, etc.)
Files like CSV & Excel
4๏ธโฃ Advanced Data Quality Operations
Filter, dedupe, validate, cleanse, normalize, enrich, and reshape data with simple SQL queries.
5๏ธโฃ Cross-Source Joins & Comparisons
Join app data with CSV/Excel files or compare records across systems in a single SQL step.
6๏ธโฃ Significant Performance & Task Efficiency
Offload heavy logic into SQL Transformations โ fewer loops, fewer tasks, faster recipes.
Supports file-based data as rows (CSV/Excel parsing becomes easy)
Dynamic schema handling reduces maintenance
Built-in aggregations for reporting (SUM, COUNT, AVG, GROUP BY)
Error handling and validation within SQL
Simple Excel โ CSV conversions
Great for bulk dataset processing (thousands to millions of rows)
โ Handling large datasets
โ Complex mappings & data reshaping
โ Converting or cleaning file-based data
โ Joining or comparing multi-source data
โ Preparing data for SAP, Salesforce, Marketo, Snowflake, etc.
โ Optimizing recipe performance & reducing task usage
๐น Quarterly reporting:
Join Salesforce Opportunities with CSV-based marketing campaign data, filter inactive campaigns, aggregate revenue, and output a clean Excel file.
๐น Bulk data purging & export:
Generate thousands of rows into a CSV in one step โ perfect when Data Tables hit the 1000-record limit.
๐น Multi-sheet Excel normalization:
Merge multiple Excel sheets, remove duplicates, standardize column names, and export a unified CSV.
SQL Transformations unlocks high-volume, high-complexity data processing inside Workato with unmatched speed and flexibility.
If your workflows involve large datasets, multi-source integrations, or advanced data cleansing โ this tool is a must-use.
2 weeks ago
Hi @dianest ,
Thank you for bringing new deep dive post, itโs a great initiative and truly helpful for the community.
Here are my thoughts with few examples
Perform complex transformations without external databases or infrastructure.
No Storage Constraints
Fully in-memory execution ensures scalability for large datasets.
File-Based Data Handling
Merge CSV, Excel, and other file formats with app data seamlessly.
Advanced Capabilities
Data Quality Enhancements
Deduplicate, validate, normalize, and cleanse data at scale.
Multi-Source Integration
Combine data from:
Example: Match Salesforce Opportunities with CSV-based campaign data.
Performance & Efficiency
Recipe Optimization
Offload heavy logic to SQL, reducing task usage and improving speed.
Dynamic Schema Handling
Automatically adapts to schema changes, minimizing maintenance.
Built-In Analytics
Perform aggregations (SUM, AVG, COUNT) and grouping directly in SQL.
Additional Unique Features
Conditional Transformations
Apply business rules dynamically (e.g., region-based filtering).
Data Enrichment
Add calculated fields like revenue projections or performance scores.
Error Handling & Validation
Flag invalid rows and route them for review before final output.
Format Conversions
Effortless Excel โ CSV conversions without complex steps.
Scenario:
Quarterly report combining Salesforce Opportunities and Marketing Campaign data.
Solution Steps:
Impact:
Thanks and regards,
Shivakumara K A
