Changing Date Format in Recipe for Google Drive Folders
energidi
Hi everyone,
I have a Workato recipe that connects Salesforce with Google Drive.
In the recipe, Iโ€™m creating Google Drive folders where the folder names are based on Contact names and their Date of Birth.
This setup works perfectly.
However, I want to change the Date of Birth format, which comes from the 'Date_of_Birth__c' Contact date field, from YYYY-MM-DD to MM-DD-YYYY.
How can this be achieved?
Hi @energidi ,
solution:
Image_1: If the incoming date field is of type Date, there is no need to convert it to Date again. However, make note of the brackets.
Image_2
: If the incoming date field is of type String, it is required to convert the source field to Date (i.e., strftime works on the Date field).
Shivakumara Avadhani
8 REPLIES 8
rachelnatik
There are several date formulas that can accomplish this.
Use this:
"2020-12-12".strftime("%m-%d-%Y")
energidi
Thank you, @gary1 !
The formula works perfectly when written as follows:
[Date_of_Birth__c]=.strftime("%m-%d-%Y")
(The 'Date_of_Birth__c' field is sourced from an output).
However, attempting the formula below, which is what I need, results in the error: Formula has errors
[ContactName__c]_[Date_of_Birth__c]=.strftime("%m-%d-%Y")
(The 'ContactName__c' field is sourced from an output).
Even after removing the underscore, the error persists.
Hi @energidi ,
solution:
Image_2
