Custom connector with two step authentication
Giorda62
Hello,
I'm pretty new to workato and not quite familiar with Ruby.
I need to write a custom connector that authenticates using a POST request passing username/password and receives back an auth token; the Token will then be used in the header of following requests; I'm struggling in identifying the correct form to write the "authorization" block of the "connection" section; I've tried using the following:
  "connection": {
    "fields": [
        "name": "username",
        "label": "Username",
        "hint": "Enter HDA username for authentication.",
        "optional": false
        "name": "password",
        "label": "Password",
        "control_type": 'password',
        "hint": "Enter your password for authentication.",
        "optional": false
        "name": "BaseURL",
        "label": "Base URL",
        "control_type": 'URL',
        "hint": "Enter base URL for HDA integration.",
        "optional": false
    "authorization": {
      "type": "custom_auth",
      "acquire": {
        "code": {
            "post": {
            "url": "https://XXXXXXXXXXX/api/login",
            "headers": {
                "Content-Type": "application/json"
            "payload": {
                "username": "::username::",
                "password": "::password::"
            "response_format": "json"
            "response_mapping": {
            "token": "token"
      "base_uri": "https://XXXXXXXXXXX/api",
      "apply": {
        "headers": {
          "Authorization": "::token::"
  test: lambda do |_connection|
    get("::BaseURL::")
  end,
But I get the following error: Expected lambda for 'acquire' in hooks but got hash.
Any hint or suggestion?
Thanks a lot,
Giordano
0 REPLIES 0
