Data transformation using Javascript Connector
jani-swinnen
Hi all,
I'm currently trying to do some data transformation using the Javascript connector but I can't figure out how to corrrectly configure the output. I'm trying to format a JSON body for a HTTP request to the Slack chat.scduleMessage endpoint.
In my recipe I set a variable to a JSON string, which I need to input into the Javascript connector, I then use JSON.parse to parse this string, but when I return the JSON.stringify on the next line, it ends up as a null value... My output schema is just a string named payload and in the next step the payload datapill is an empty string.
The JSON.parse does not give me an error so I have to assume the string gets parsed, but somehow, somewhere it ends up as null.
Does anyone have any experience in this situation?
Star Chef I
Star Chef I
I just ran a quick test and was able to get JSON.parse and JSON.stringify to work without issue. It might be how your script is returning the output. I found that part a bit tricky when first working with the JS connector.
I attached some images of my setup and script so you can see how it works and hopefully replicate it.
โ€ƒโ€ƒ
โ€ƒ
Patel0786
 i also create a recipe for data transformation using JS snippet by workato, in this recipe i have a group of JSON object and i'm doing data transformation like converting firstName, lastName etc  to - (based on requirement) using JS code.
Recipe:-  https://app.workato.com/recipes/54842488?st=22358e2f16126f8b0aa51e349ae0de7633781b47a307c56fdd951d59...
