a month ago - last edited a month ago
Error calculating input for field 'myField': wrong number of arguments (given 1, expected 0)
I need help figuring out what this error means--why does it expect 0 arguments? How can I fix this?
This is the formula that I have mapping to the field: [DATAPILL]&.to_date(format:"MM/DD/YYYY")
Please let me know if any additional info is needed. Any guidance is appreciated, thank you!
a month ago
Hi @rpatrick_,
your pill may be "now" or "today", which does not return a datetime input as a user-defined string by default, so you need to add "strf" formula to make it user-defined string, because of that, it is throwing an error. Please check the below attached image and try it out once, if you face any error again, please do posted here.
Thanks & Regards,
J Rajesh Kumar.
a month ago
Hi @rpatrick_ ,
After reviewing the requirement, it appears you are passing dateTime or date as input, which is causing the error:
This happens when using the to_date formula, which returns the format YYYY-MM-DD (Required response).
If you are passing a date or dateTime value to to_date, try converting it to a string first. (A sample example is provided below.)
a month ago
I think you are correct about the type of input being the issue. I first tried with the formula as you've shown, but it still errored. I changed the formula to: &.to_s.to_date(format:"YYYY/MM/DD") - this time getting the nil input error. I then tried: &.to_s&.to_date(format:"YYYY/MM/DD"), and it no longer errors on empty inputs, but it does say invalid date for datapills that are not empty. I noticed that the trigger output has 0022 as the year instead of 2022, so I changed the formula format to be YY/MM/DD, but I still see invalid date.
What do you think I am missing?
Thanks for your help,
Renee
4 weeks ago
If your Last Provision Date is "0022-05-15", you're kind of hosed because that's not a valid date whether it's a string type or date type. You need to fix that first -- which should probably be fixed upstream in the source application providing the data. The to_date method won't work with "22-05-15". The year needs to be a 4-digit year value.
You can do something wild like this. It assumes all years are 2000 or greater. If you have a year in the 1900s, you're hosed again.
["0022-05-15".split("-")[0].to_i + 2000, "0022-05-15"[5..-1]].smart_join("-").to_date
## output >> "2022-05-15" as date type
