Format SQL Results into Email
dunncrew
Hi, In my recipe, I am selecting 2 columns from a SQL table, and want to put the results in the body of an email.  I get results, but they look like this:
{"rows"=>[{"datetimeoftxn_b5896cc8"=>"2023-10-09 13:59:23.797000000", "listoutput_0ec6e5e5"=>"Test_Last_Name1, Test_First_Name1, Test_Door_Name1                                                  "},
{"datetimeoftxn_b5896cc8"=>"2023-10-09 13:59:23.797000000", "listoutput_0ec6e5e5"=>"Test_Last_Name2, Test_First_Name2, Test_Door_Name2                                                        "}]}
I just want the data in my email like this:
2023-10-09 13:59       Test_Last_Name1, Test_First_Name1, Test_Door_Name1
2023-10-09 13:59       Test_Last_Name2, Test_First_Name2, Test_Door_Name2
The 2 SQL Columns are datetime and nchar. What's the best way to get just the data in my email ?
I'd recommend using a message template to format the data into a nicely formatted HTML table, and then insert the table into the email body.  You'll need to brush on HTML for the formatting and mustache for the parsing in the message template, but it's definitely worth the effort -- especially if you may need to create more emails in the future.
For step 8, replace "Step 5 Output" with Step 5 Message. IMO it's very rare that you will use the "Step # Output" directly. You generally want to use the data pills within the step's output.
Anyway, switching gears: let's try something different.
First, make a variable list:
By doing this, you now have the ability to parse and transform (clean up) the values as they go into the list:
Using to_time makes the date string a date object and then using strftime converts it back to a string using the specified formatting. Using strip on the output removes leading/trailing whitespace characters.
Now that it's cleaned up, you can pluck/to_csv and it'll be a lot closer to what you want in your email, but I still recommend using a message template! It's only a few extra steps from here.
15 REPLIES 15
dunncrew
Your other suggestions got me a usable result. I will now start looking into Message Templates.
dunncrew
Thanks. I will give those ideas a try.
I don't know what is appending these characters _b5896cc8 , _0ec6e5e5 to the end of the column names.
Listoutput_0ec6e5e5
dunncrew
Input data from MS-SQL Server
DateTimeOfTxn                                 ListOutput
2023-10-09 17:38:36.243             Smith, Joe, Front Door
2023-10-09 17:38:36.243             Jones, Mary, Back Door
2023-10-09 17:42:37.770             Bishop, Dennis, Side Door
Desired result is an email with date-Time formatted like this:
10/09/2023 17:38           Smith, Joe, Front Door
10/09/2023 17:38           Jones, Mary, Back Door
10/09/2023 17:42           Bishop, Dennis, Side Door
SQL โ€œSelectโ€ to get the records
Log records to CSV
Email from Step 3 with non-data characters removed with gsub (very messy, data wraps, wrong date format)
    2023-10-09 17:38:36.243000000 ,    Smith, Joe, Front Door        ,    2023-10-09 17:38:36.243000000 ,    Jones, Mary, Back Door        ,    2023-10-09 17:42:37.770000000 ,    Bishop, Dennis, Side Door        ,    2023-10-09 17:42:37.770000000 ,    Fisher, Emily, Emergency Door
Email from Step 3 โ€œRowsโ€. Contains all the โ€œjunkโ€ characters.
[{"datetimeoftxn_b5896cc8"=>"2023-10-09 17:38:36.243000000", "listoutput_0ec6e5e5"=>"Smith, Joe, Front Door        "}, {"datetimeoftxn_b5896cc8"=>"2023-10-09 17:38:36.243000000", "listoutput_0ec6e5e5"=>"Jones, Mary, Back Door        "}, {"datetimeoftxn_b5896cc8"=>"2023-10-09 17:42:37.770000000", "listoutput_0ec6e5e5"=>"Bishop, Dennis, Side Door        "}, {"datetimeoftxn_b5896cc8"=>"2023-10-09 17:42:37.770000000", "listoutput_0ec6e5e5"=>"Fisher, Emily, Emergency Door        "}]
Email from CSV. Data wraps and needs formatting
{"message"=>"2023-10-09 17:38:36.243000000,\"Smith, Joe, Front Door        \"\n2023-10-09 17:38:36.243000000,\"Jones, Mary, Back Door        \"\n2023-10-09 17:42:37.770000000,\"Bishop, Dennis, Side Door        \"\n2023-10-09 17:42:37.770000000,\"Fisher, Emily, Emergency Door        \"\n"}
FYI,  If you ask my โ€œwhyโ€ am doing something, itโ€™s probably because it at least didnโ€™t cause an error ! ๐Ÿ˜€
dunncrew
Extremely Helpful. Thanks !
