โ05-17-2025 05:59 AM
Hi Team,
I wanna build a recipe with following flow.
1. Trigger from a webhook with 5 fields.
2. Connection with a third-party product a, where user would have configured the username, password earlier.
3. Call product a and bring some data.
4. Add all this data and 5 fields I got initially into a file.
5. Call product b api which accepts this file as API request with no authentication.
a month ago
Hi, this should be quite basic/easy to do in Workato, here is recipe example i mocked up for you
https://app.workato.com/recipes/62531450?st=0d9aee474a56a6154b750a593f54ff36b915731117279a0f3a5b7a4e...
1. trigger, just use the native webhook as trigger, add your fields you need as Payload Schema, for example i added field1,2,3,4,5
2. Connect to any system you want to next step (my step 3) for example i do salesforce and use one of the incoming fields as lookup to get a Contact by email
3. previous setep
4. not sure which file format you want here so i used CSV composer to create one, using the initial 5 fields plus one salesforce field
5 finally doing POST http request to any HTTP endpoint, when creating connection just select no auth, add the csv content from previous step (compose csv step 4) as payload
