2 weeks ago
I am using Search files or folders actions in SFTP server action. In the search term , i have used this expression : \w+_\d+.CSV
I would like to check , for example : FileName_20241212.CSV ; After the filename_[IS THERE A NUMBER?].CSV
For some reason, my expression looks correct but does not seem to be working in workato , i have checked in the regex portal
I do not see any errors or any outputs.
Any lead will be highly appreciated.
Thanks Community
15 hours ago
Hi @vijayalakshmi ,
We are looking into why Regular Expressions are not working. As a workaround, you can try using the following expressions. See the sample below:
I also noticed a support ticket that you have raised. Our team is currently working on it. Please check the updates/status of the ticket.
