Friday
Hi guys,
I am trying to build an automation triggered by any new mail received in my account. What I would like to do is that each mail can be sent to an owned Gem (with its knowledge) and that this one could generate a response then. However, when exploring the Gemini app in Workato I can't see any action that actually has a conversation with a Gem.
Does anybody know how to proceed?
Thank you!
Friday
Hi martipa
Yes, I have implemented a Workato recipe for this use case. The automation is triggered whenever a new email is received in Outlook. The email content is then analyzed using the AI by Workato action, which generates a suitable response. Finally, the response is automatically sent back to the sender via Outlook Mail.
This setup ensures that every incoming email is handled in real time with an AI-generated reply. If deeper integration with a Gemini Gemโs knowledge base is required, the same flow can be extended using the HTTP connector to call the Gemini API.
11 hours ago
Hi @Haritha ,
I think my workflow is a bit different. The mail received should go through the knowledge stored in a Gemini's Gem and from there generate a response. Then, that response should be sent in a message through a Slack bot to a certain channel. However, I can't find any action in Workato that is indeed interacting with my Gem. Do you know if that's possible? how?
10 hours ago
Hi @martipa ,
If your using Private Gem need to host on GitHub or any other platform first . From that platform related to project create a API key and credentials , connect in workato. If it's wotkout please let me know or tried with method let me know
Thankyou
8 hours ago
Hi @Obugari ,
I am not sure what you are referring to when taking a Gem to GitHub. Just for clarification. What I am trying to make intercat with Workato is a Google Gemini Gem, here some info on what is it.
Should I still get the Github approach? could i get more guidance if it is that way?
