02-05-2026 04:01 AM - edited 02-05-2026 05:14 AM
Hi, when reaching out to an application with the HTTP connector I often get an error for "invalid_token, the access token provided has expired". This seems to happen every time a new token is needed for a call. When repeating the job, the call goes just fine.
First call result:
Second call result:
Does anyone have an idea what the cause could be? Also I never encounter this problem using Postman.
To mee it seems like the token was used too quickly for the target application to be able to validate the token.
In the debug of the HTTP request I see no details of the actual headers/payload/response
What is the best-practice solution I could try?
I have not seen anything like a delay in the HTTP connector settings and it seems to extreme to make a custom connector.
The target application accepts the usual Oauth2 flow, with grant_type: client_credentials.
This results in a bearer token for all following calls.
I look forward to your inspiration, also: please let me know if this is not the right place for this question.
Kind regards,
Vincent
02-05-2026 12:05 PM
Hi @vbosma, for the First workaround can you send the response/error of the http action?
How the second workaround, you can create two http invocation if possibile:
02-05-2026 09:04 PM
Hi @vbosma ,
In the retry mechanism, also inspect the error response body to identify token-expiration errors.
If the error is related to an expired access token, skip the retry. Instead, handle the error by first refreshing the token explicitly (preferably using a separate callable recipe or function dedicated to token management).
Once the token is refreshed, re-execute the same business logic within the error handling block, rather than relying on multiple retries.
This approach avoids unnecessary retries, reduces failed jobs, and results in more predictable behavior when handling token expiration in Workato.
02-06-2026 12:47 AM
@shivakumara This seems like another way to do the token management, I agree. Also thinking about the amount of consumed tasks. I think this might be the way after some time with a bit more experience (and excessive tasks-usage). Thank you!
