Best workaround for filtering by dates in a SQL collection
eyoder
Hello! We have a use case where we only want to query records that have a field with a date between 2 values. (If it matters, they are coming from a csv and will go back into a smaller csv.) The problem is that you can't reference a date in the SQL collection by Workato query. What creative solutions exist? Workato workbot suggested 'Mapper' but I fail to see how that would apply. Thanks in advance!
Hi, can you clarify what you mean by this?
"The problem is that you can't reference a date in the SQL collection by Workato query."
Once you make the Collection, you use another Collection query action to write a SQL query to access its data. You can use comparison operators on date fields to find matches within specific dates.
Hmm, this is in the docs: https://docs.workato.com/en/features/collection.html#actions under 'collection date error' and I assumed that is why we haven't been able to make this work properly. Thank you for your consideration!
That is when you want any dateTime fields in output then you need to convert that dateTime pill in the doc mentioned format if not it throws that error
Bhagya_pola
Hi @eyoder
I think you can try in the way shown in below attached images, let me know if this doesn't help
Screenshot 2025-09-12 001141.pngScreenshot 2025-09-12 001125.pngScreenshot 2025-09-12 001148.png
