โ08-22-2022 03:48 PM
I would like to recieve a notification when a file is updated in BIM360, however, both triggers "New or updated document in a project folder" or "New or updated document in a project folder and subfolders" dont give the option to select the desired file i would like to monitor for updates (new versions). It only asks for Hub, Project and Folder.
โ08-22-2022 03:55 PM
Hi, can you try setting the name attribute to match the file name that you would like to monitor in the trigger condition? In this way, the recipe will only run for jobs relating to the specific file.
โ08-22-2022 04:53 PM
That seems to have worked thanks! However, i now need to retrive the link to the file. But the link is associated with webView: (see below) and i cannot seem to find it / link it using a datapill.
โ08-22-2022 05:16 PM
No worries, In Workato, using the formula mode you can traverse and pluck any nested data coming in as JSON, check it out here - https://docs.workato.com/formulas/array-list-formulas.html#pluck.
You can use logger action to log the output of the formula and test it out until you arrive at the right data.
โ08-22-2022 05:48 PM
Still unable to get the link. It seems that it does not even recognize webView as its own line, only Self. As a side note, instead of this, i could manually link the file in the body of the email. How can I embed a link within text in the body of the email when crafting it? *I would like people to be able to click "Link to file" and it takes them to the file.
