Consuming Kafka events using Workato
krishna
We are planning to leverage workato to consume events from Kafka generated from our product. Did anyone worked on similar use cases and aware of any limitations or gotchas i need to be knowing before implementing it?
13 REPLIES 13
steven-marissen
We are looking into a similar usecase with either Kafka (self managed) or Confluent Cloud (managed kafka) in a POC phase. We've been able to produce & consume messages using Workato.
I do think the confluent cloud connector could offer a broader configuration / features. Some examples are: consume only from a specific partition instead of all of them (=default). Also not sure how consumer groups would work with Workato (= concurrency greater then 1?).
Apart from that something on our to-do list to test rigorously is the behaviour:
- When a new version of the recipe is promoted, does it impact off-set?
- Impact of starting a clone on off-set
- Impact of an incident at Workato itself
- Handling errors (DLQ topic or something else)
- Monitoring ( x amount messages produced into topic = amount of messages consumed from topic? If not, how to identify delta's)
triesen
We're also using the Confluent connector, and highly recommend Confluent ๐Ÿ™‚ Workato + Kafka has been pretty straight-forward for us; the main pre-requisite is getting the schema defined correctly (if not already defined). Happy to collaborate on anything if its helpful, and +1 on Steven's point to see if Workato can add broader configuration / features.
Hi Tony,
We do experience an issue when we consume from a Confluent Cloud topic, we are able to pull messages from the topic into Workato but the consumer never appears in the confluent cloud data flow or under cluser -> clients -> consumer groups.
This is an essential piece for monitoring consumer lag etc.
Have you encountered this issue before?
Thanks in advance for your feedback.
rak-9177
We builded lot of integrations in Workato in kafka. Happy to share information.
