Consuming Kafka events using Workato
krishna
We are planning to leverage workato to consume events from Kafka generated from our product. Did anyone worked on similar use cases and aware of any limitations or gotchas i need to be knowing before implementing it?
14 REPLIES 14
rak-9177
We found a bug and some design issues in kafka connector process and currently working with Workato product teams. Workato team is acknowledged and working on this. I can provide you more details n couple of days.
Again appreciated for your input. We've also noticed the same for Confluent Cloud connector which also needs to be enhanced for it to work well with CC. In it's current form no monitoring (or very limited) in CC can be done.
Keep us posted on the progress! ๐Ÿ™‚
Sure definitely!
shashankbyakod
I am facing issue with the Kafka connector integration, I wanted to setup kafka connections with plain text or json format of data. Hence, not relying on the Schema registry. But wile editing the recipe, i was not able to make changes on the script. Pls help here, whether we do have options to use non-avro schema based.
devidmithen
Not applicable
Nice information.
