Convert string to json and then iterate through the JSON
kapil775
Hi everyone,
I have pasted a sample JSON below which is in string format.  I need to do below two activities. Please suggest how to do it in Workato.
1. Convert the string to JSON object.
2. Iterate through the two "results" objects present inside the JSON.
"count": 2,
"next": null,
"previous": null,
"results": [
"date_created": "2024-09-17T00:43:47.536708Z",
"user": "ld",
"object_repr": "SOX Test Access Level <fy24-sox-test-dl-sox-test-access-level>",
"parent_repr": "FY24 SOX Test <fy24-sox-test>",
"action": "UPDATED",
"comment": "",
"object_type": "Access Level",
"object_id": "270231",
"parent_type": "Access Container",
"parent_id": "312767",
"audit_fields": [
"action": "ADDED",
"field_name": "member_users",
"field_data": "osebastian",
"object_id": "24150",
"object_type": "user"
"action": "ADDED",
"field_data": "jguieb",
"object_id": "27870",
"action": "ADDED",
"field_data": "gorino",
"object_id": "31933",
"date_created": "2024-07-12T00:42:47.986838Z",
"user": "ldeguzman",
"object_repr": "FY24 SOX Test <fy24-sox-test>",
"parent_repr": "",
"comment": "",
"object_type": "Access Container",
"object_id": "312767",
"parent_type": null,
"parent_id": null,
"audit_fields": [
"action": "REMOVED",
"field_name": "delegates",
Hi @kapil775,
Did you try using Parse JSON document action.
Hi @kapil775,
