โ08-14-2023 08:46 AM - edited โ08-28-2023 01:39 PM
I have a custom object named "Items" in salesforce, and I want tasks to be created in ClickUp whenever an Item is created, if the task is created then it should be updated.
is there anything I'm missing?
a week ago
I was able to fix it, Just matched the ID and the name of the item. In order for it to work I Created two apps in ClickUp API. One for Workato (I asked them for their return URL) and one for Salesforce. Then I created the Recipe Below and it works fine. It is not bi-directional because it was not a client request, but still tested and works bi-directionally.
โ08-14-2023 02:16 PM
Hey @eliezeraugust0, do you mind reattaching the photos you provided? I can't view on my end.
โ08-28-2023 01:38 PM
Here are the pictures
โ08-15-2023 11:30 AM
One method is to run your recipe in schedule and have Query to Items which was created.
Another method is to use webhook. Create a webhook in salesforce and have Workato run recipe based up on webhook.
a week ago
