Tuesday
Hi everyone,
title: 'Lexsynergy',
connection: {
fields: [
optional: false,
hint: 'Your Lexsynergy API key'
optional: false,
hint: 'Your Lexsynergy secret key',
control_type: 'password'
authorization: {
type: 'custom_auth',
acquire: lambda do |connection|
end,
apply: lambda do |connection|
end
base_uri: lambda do |_connection|
'https://api.lexsynergy.com/1.9/'
end
test: lambda do |connection|
url = 'https://api.lexsynergy.com/1.9/tlds.json'
api_key = connection['api_key']
api_secret = connection['api_secret']
request = call(:request_signer, api_key, api_secret, 'GET', url, '')
get(url).headers('Authorization': request['authorization_header'])
end,
custom_action: true,
actions: {},
triggers: {},
methods: {
request_signer: lambda do |api_key, api_secret, method, url, body|
# Calculate timestamp and nonce
timestamp = now.to_i.to_s
nonce = uuid
realm = 'api'
# Construct the string to sign
string_to_sign = "#{realm}\n#{api_key}\n#{nonce}\n#{timestamp}\n#{method.upcase}\n#{url}\n#{body}\n"
# Generate HMAC signature
signature = string_to_sign.hmac_sha256(api_secret)
encoded_signature = signature.encode_base64
# Construct the Authorization header
authorization_header = "lexsynergy-http-hmac realm=#{realm}&key=#{api_key}&nonce=#{nonce}×tamp=#{timestamp}&signature=#{encoded_signature}"
{ 'authorization_header' => authorization_header }
end
object_definitions: {},
pick_lists: {}
yesterday
Good day!
We do have a sample connector that uses HMAC, which you can find in our Community Library. I have included the link for your convenience: https://app.workato.com/custom_adapters/125161/code?community=true.
This should provide you with a good starting point for building your custom connector.
If you require further assistance or have any specific questions, I suggest submitting a ticket to our Support Portal. Our team of experts will be more than happy to assist you with any further queries or concerns you may have.
Thank you
yesterday
Good day!
Thank you
11 hours ago
Thank you, that was indeed helpful in finding a solution.
