Custom Connector HTTP response 302 throws an error
fsantaana
The site I'm trying to login with a custom connector first initiates login via HTTP FORM, but then once logged in, the response is a redirect (HTTP 302) to the "next" url which was passed in via the original request. The Workato response handler treats a 302 as an error and stops executing further code. Is there a reason Workato treats a 302 status as an error? It is not an error but really a redirect, and the redirect can return a 200.
marlon-muela
In Workato, error 302 is a result when a change in the URL occurs. This mostly happens with custom domains. You might need to use your subdomain.
marlon-muela
