โ05-03-2024 03:34 AM
I am unsure if this is the correct place for this but for lack of alternatives I'll try my luck.
Currently the limit for data tables is 50 columns. This limit is reached quite easily as the current Workflow Apps architecture requires flat tables for data field inputs. It would be great to extend this limit to at least 100 columns per table.
Thank you,
Julian
โ05-14-2024 11:19 AM
Hi @JulianPiek,
Thank you for voicing this request! You can submit feature requests to our product team a couple of different ways:
Hope this helps!
Meghan
Hi @JulianPiek,
Hope this helps!
Meghan
โ05-15-2024 12:09 AM
Thanks for your reply Meghan.
Unfortunately I am not able to load the feedback part of the AssistIQ slider.
I only get a blank page with the error below.
The web page at https://feedback.us.pendo.io/html/widget/notLoaded.html might be temporarily down or it may have moved permanently to a new web address.
a month ago
@JulianPiek โ I'm sorry to hear that! If you are able to follow option #2 for submitting feedback (via a ticket), please do so. That way, the proper team can help you out. Thanks!
