Hello All, I am getting array data from API, I am inserting it in salesforce in a multiselect picklist field but I am getting the data there as array, but I want the values in picklist separately, what can I use to do this. I am attaching screenshots
harendra
scharan
Hi Hrendra
Did you specify the response schema so that each value will be saved in a list format with field names.
So that you can use one the one which you want.
p-held
Hi Harendra,
for me it worked to send a string with the values separated with semicolon to Salesforce for a multiselect picklist field.
So in your case just do listname.pluck('fieldname').join(';') with your list and map the resultstring to the Salesforce field which should lool like SF_fieldname:"a;b;c"
