Sunday
Hi all,
This may be a simple 'yes/no' but just posting here in case I'm missing something - I am using the Slack Workbot to send messages and manually 'build' the block kit.
It looks like the 'Header' block is not available?
Header on Slack is larger than normal text, and it is different than bold (using *text* markdown):
It is
Anyone ever do this?
Monday
Hi @Nmatan,
Based on your post, I understood the following:
You are asking whether you are missing something in how to use the Block Kit to include a Header block or if the Header block is not supported in Slack's Workbot implementation.
1. If the answer is Yes, then Slack does support the Header block, and it can be incorporated into your development.
2. A Header is similar to the concept used in Word or other documents, where it is used to highlight and differentiate text by making it bold and prominent.
- For example: Title โ Subtitle โ Header โ Normal Text (as seen in documents for structuring content).
3. in your case it is behaving properly.
Please add more points if the provided solution is not clarified your doubts.
Shivakumar K
