Migrating Recipes from one workspace to other workspace in Workato
Patel0786
I know it is possible to share recipes privately using link and share it is possible to share to community.
Is there any possibility to share recipes, folders, assets in standard way or any other way from one workspace to other workspace in workato?
4 REPLIES 4
Hi @Patel0786 ,
Yes,
1. It is possible to export the appropriate project folder from your current workspace (Tools --> Recipe life cycle management --> Export --> Select the required project folder, subfolder, etc.).
2. Navigate to your desired workspace to import it. Create a parent folder structure in the workspace, then (Tools--> Recipe Life Cycle Management--> Import (choose the ZIP folder created in step 1 from your local workspace folder) --> to the parent folder you created.
Shivakumar A
thanks @shivakumara for answer, i already tried this way i'm looking for any other way.
Hi @Patel0786 ,
One more way of doing it using "Deployment" ( I am assuming here that other workspace is Test or PROD),
Note: If your Organization has chosen this subscription, the deployment option is accessible.
1.Sign in to your WDeployment.pngorkato account.
2 Navigate to the main DEV environment.
3 Open the project you plan to deploy and click the Deployments tab.
4 Click Deploy to. The following options appear in the dropdown:
     TEST
    PROD
Shivakumar K A
We can deploy from Test to Prod, but not Prod to Test. We have to "export" from Prod to Test. Why is that ?
