โ04-11-2025 08:50 AM
I'm querying a database from an API-Endpoint trigger and want to return the result as JSON.
So far nothing out of the ordinary, and it works for other usecases.
The data i do get back from the database though already contains a JSON string in one column.
An (modified) example of the result (as "raw JSON" from the job-detail view) looks like this:
"rows": [
"id": 55540,
"number": "7200",
"quantity": "2037",
"description": "Something 1/2",
"history": "[{\"car_id\":\"493\", \"position\":\"left\", \"added\":\"20181101\", \"removed\":\"20240827\", \"ref_id\":\"55\"}]"
"id": 4802,
"number": "2600",
"serial_num": "2306",
"description": "Something 2/2",
"history": "[{\"car_id\":\"84\", \"position\":\"left\", \"added\":\"20180930\", \"removed\":\"20230223\", \"ref_id\":\"846\"},{\"car_id\":\"84\", \"position\":\"left\", \"added\":\"20230320\", \"removed\":\"20250318\", \"ref_id\":\"84\"}]"
"id": 55536,
"number": "7100",
"quantity": "2037",
"description": "Desc 3",
"history": "[{\"car_id\":\"493\", \"position\":\"right\", \"added\":\"20181101\", \"removed\":\"20240827\", \"ref_id\":\"55\"}]"
"id": 55531,
"number": "7600",
"quantity": "2315",
"history": "[{\"car_id\":\"493\", \"position\":\"right\", \"added\":\"20181101\", \"removed\":\"20240827\", \"ref_id\":\"49\"}]"
"rows_count": 4
}When returning the result in the API I created a return schema that anticipates, that history should be a list (and I also tried object), with nested attributes of car_id, position, added, removed, ref_id.
The problem now is that i can not manage to make the history-column be interpreted as a list-pill to use in the return schema.
As the result set is thousands of rows, I can't manually iterate through them to convert the history-json "string" to a list that I could use afterwards (without creating thousands of tasks).
When using a schema that just uses a history-field with string type - the output is just like the example above. It contains all information, but the JSON is embedded & escaped instead of passed through.
Any idea on how to get this working as desired and simply "pass through" the JSON from the DB, without escaping it as a string?
โ04-11-2025 09:45 AM
Here's the full JS snippet for returning the full array with history parsed:
exports.main = async ({ rows }) => {
parsed = rows.map(item => (
...item,
history: JSON.parse(item.history)
return parsed;
โ04-11-2025 09:08 AM
I've dealt with similar situations before. You can't build a parser into the response schema that will "de-stringify" the string. You need to parse it in a separate action. There's a bunch of ways to do it, but to avoid loops/tasks I recommend dumping your output into a JS action and using JSON.parse like this:
exports.main = async ({ foo }) => {
return JSON.parse("{\"hello\": \"hello\"}");
};This outputs a parsed object.
...item,
return parsed;
โ04-11-2025 10:28 AM
Tanks, that works great!
I had to modify just a tiny bit:
return {rows: parsed};as otherwise it would just return an array (although in the job history UI of course it looks like an Object with an "Output: " array property) and I'm not sure how to map that to an output schema / capture it to return it in the API response.
