Python code snippet app accepting 5086 characters only as a input
gayatrikhatale
I have created workato recipe. In which I  have created variable of type string and its holding larger string as a input. In second step I have created python code snippet app which is reading the string from previous step and returning that string as a output. When I tetsted my recipe it run successfully, but it's not taking whole string as a input in second step. It's only taking 5086 characters only as a input in second step. Help me with this.
Thank you!
Hi @gayatrikhatale ,
Could you please help me with the input string which you are providing to Python script?
Shivakumara Avadhani
jadee
Having the same problem, any string above 5000 chars gets cut off when handing to the python connector. Via datapill recieved from webhook or freshly created with straight text in a variable, doesn't matter.
