Quickbook desktop connector
sidhant-chawla
Hi Everyone,
Has anyone integrated quickbook desktop / QB web connector with Workato using OAuth authentication ( username and password).
There is no option to do that with the existing connector we have in workato.
Quick response is appreciated.
Sidhant Chawla
8 REPLIES 8
Integration will be between Salesforce (VMS) and QBD. We need to sync invoices in both the systems using bidirectional sync.
Issue is authorization of Quickbook desktop. It supports basic authentication. I know there are API limitations but I'm sure there should be some way of integrating these systems.
Do you think creating custom connector for QBD would help in such cases?
We have raised the ticket with Workato #211092.
jayesh
We have evaluated a QBD connector and unfortunately due to the API limitations that is not possible.
Thank you for the quick response. Need to check external systems in that case.
jayesh
Also note that QBD is installed on-premises and behind a firewall. So this would require setup of an OPA. From a file based integration perspective you could use On-Prem Files Connector.
