Quickbook desktop connector
sidhant-chawla
Hi Everyone,
Has anyone integrated quickbook desktop / QB web connector with Workato using OAuth authentication ( username and password).
There is no option to do that with the existing connector we have in workato.
Quick response is appreciated.
Sidhant Chawla
8 REPLIES 8
anthony-oconnor
OAuth wouldnt use username/password
that would be called "Basic" auth
I can't speak to the QB connector specifically but if there's an option to use basic auth and you set that it should allow to use username and password.
jayesh
Sidhant,
QuickBooks Desktop is completel;y separate product and it does not support standard APIs. The QB Connector will not work with QB desktop. The best approach to QB Desktop integration would be to consider files based integration.
Thank you for the response, Sir but I don't think we can implement file based integration in our case. It will be more complex than what we already had in our system.
jayesh
Understand - unfortunaltly this is due to the API linmitations of QB Desktop. What are the set of use cases.
