Recipe scheduled to run Daily is polling every 5 minutes
rwitsmc
I have a recipe that I've set to trigger daily at 9am, but it keeps polling every 5 minutes, and because of this it hits the trigger non-activation limit and stops the recipe. How do i stop it from polling every 5 minutes as there is no polling interval setting for scheduled recipes?
Martin
2 ACCEPTED SOLUTIONS
rwitsmc
Hmm, created a new recipe with exactly the same settings and that one triggers correctly...
compared to the original recipe...
The original recipe must have some hidden setting somewhere that's corrupting the trigger.
marlon-muela
It's good to know that you were able to resolve the issue. I would also recommend using days of the week under the trigger options if you want to select specific days to trigger the recipe.
rwitsmc
sampath
You can setup to run the schedule dailyScreenshot 2023-07-25 093700.pngScreenshot 2023-07-25 093612.png. Please refer to my screenshot.
Well of course that's how both jobs are setup, exactly as shown in your screenshot, but the original job I created still triggers every 5 minutes. It's as if it's retained the default trigger setting that it should've wiped when setting up the daily schedule (which is a bug).
marlon-muela
