โ07-24-2023 03:55 AM
I have a recipe that I've set to trigger daily at 9am, but it keeps polling every 5 minutes, and because of this it hits the trigger non-activation limit and stops the recipe. How do i stop it from polling every 5 minutes as there is no polling interval setting for scheduled recipes?
Martin
โ07-24-2023 05:58 AM
Hmm, created a new recipe with exactly the same settings and that one triggers correctly...
compared to the original recipe...
The original recipe must have some hidden setting somewhere that's corrupting the trigger.
โ07-25-2023 12:53 AM
It's good to know that you were able to resolve the issue. I would also recommend using days of the week under the trigger options if you want to select specific days to trigger the recipe.
โ07-25-2023
01:11 AM
- last edited on
โ07-25-2023
05:55 AM
by
meghan-legaspi
Thanks for that suggestion Marlon - I hadn't thought of doing the day selection that way, but it makes sense so I will update the recipe.
