SharePoint Lists Column Names Not Showing
ssrikantam
Hello. I am trying to search in a SharePoint List and map the response column data pills, but the column datapills doesnt show up in subsequent steps.
An alternate way is to use formulas and extract values in how we usually do with hashmaps, but can anyone please help if I am missing any steps?
I also not able to find any option to select specific columns that will end up being in OData's select query. Did anyone happen to try this out?
roland-daane
Use the http connector and use the Json output in the api result scheme.
Beware that a list returns 5000 items and that you need to paginate.
