2 weeks ago
Hi all--
I'm not sure if anyone has run into a similar issue but I'm finding that using workato automation to sync Salesforce Opportunity related files to a Sharepoint document library run into a 400 request error during upload and the limit seems to be at about 260MB-- has anyone else run into this issue and been able to extended the timeout during of upload?
a week ago
Hi Chua, sharepoint should support file streaming but maybe the timeout is because Salesforce Opp does not, have you tried dumping the file first into a storage system like s3/blob file storage/OneDrive and do you get the same error? and then moving it to SharePoint?
was checking this page, if you have a trigger which is based on a Filestream supported Workato connector you should be able to move it without getting timeout. Like for example s3 > SharePoint: https://docs.workato.com/features/file-streaming.html#how-to-use-file-streaming
