[Solved] Hi Everyone, i'm trying to connect my sql server to workato, here is the error i get. did anyone succeeded to connect? Thanks
andrian-davinta
8 REPLIES 8
philipp-schone
Is this Database on Premise? If yes you need to select the Gateway (OPA). If this is a cloud instance you need to provide a FQDN (full qualified domain name). In your config you just have a simple Hostname
philipp-schone
This Link explains the OnPremise Config https://docs.workato.com/on-prem/agents/connection.html
muniraja-katuru
We can't connect my SQL directly to the workato, you can connect using the on-prem agent.
andrian-davinta
thanks for the help, i tried to setup on prem agent, any suggestions?
