Unique List of records from an Epicor BAQ
johnw
I have an Epicor BAQ with a list of Order Transactions that I use within a recipe that's working perfectly.
in a different recipe I want to see a list of Unique Order numbers on this report and didn't want to create a new BAQ
my thought was to execute the BAQ but only retrieve the 3 fields I need which will have lots of duplicates since every order can have multiple transactions.
was hoping there was some way to only show unique records when I execute the BAQ based on the 3 visible fields but don't see anything obvious... is there some combination of pluck and unique that works on a whole record as opposed to just one field in the record?
John
Got it. Here's the easiest way I can think of doing this:
  1. Run your query to get results
  2. In a logger, do results.uniq. This will return an array of unique objects. This assumes the objects in your array are 100% identical. If even one key/value is different,
  3. Add a JSON parser and copy/paste the output of the logger as the Sample Document (this has to be text and not a data pill)
  4. In the JSON parser action, add the logger data pill as the Document
  5. The JSON parser will output a list, so you can use it as your input to your loop
Give this a shot and let me know if you get stuck.
