yesterday
When attempting to use the Woocommerce connector i noticed that there is zero documentation related to the Woocommerce connector in the workato documentation (https://docs.workato.com/connectors/prebuilt-connectors.html),
This was a bit of an issue especially as the setup wasnt a simple sign in, The connector uses is out of date / deprecated version of the woocommerce API requiring a separate legacy API plugin install in the latest version of Woocommerce, and the Permalinks default setting in wordpress to be changed before the API can be used (found this via the Woocommerce api docs).
Is this connector code owned by Workato?
- If so is there any intention of updating this to use the latest integrated wordpress api (https://woocommerce.com/document/woocommerce-rest-api/)
