โ06-19-2025 12:30 PM
currently i am trying to set up a system that will automatically email our employees there wrike tasks at the beginning of every monday. my knowledge on the builder and formulas is limited, so i have been having people help me and also getting help from Gemini to help. my issue is that in step 5 of my recipe, i was told to "Create a Variable -> Label: Tasks Due this Week -> Data Type: List".
From there I updated the schema to this
After doing that, my table looked like this.
However, after this I made a repeat loop
But after the that, It ask me to add the list "Tasks Due This Week", and no matter how I changed the schema or messed with other parts, I could not get it to appear in "List Name"
If anyone has any guidance, it would be greatly appreciated!
โ06-19-2025 12:55 PM
Hi @collin_baker_4
To loop you need a list, instead of creating variables go with list.
In variable by workato choose action as Create List (Batch)
then create some dummy field in it and then edit schema of it completely with below one and name the list
then you should be seeing the list to map in loop
"control_type": "text",
"label": "Title",
"name": "Title",
"type": "string",
"hint": "Defaults to nil if not supplied.",
"optional": true,
"sticky": true
"control_type": "date",
"label": "Due date",
"render_input": "date_conversion",
"parse_output": "date_conversion",
"name": "Due_date",
"type": "date",
"optional": true,
"sticky": true
"label": "Status",
"name": "Status",
"type": "string",
"optional": true,
"sticky": true
"label": "Permalink",
"name": "Permalink",
"type": "string",
"optional": true,
"sticky": true
"properties": [
"label": "Title",
"name": "Title",
"type": "string",
"optional": true,
"sticky": true
"label": "Project",
"name": "Project",
"type": "object",
"optional": true,
"sticky": true
Please refer the below images
โ07-01-2025 07:21 AM
Hi there! @collin_baker_4 ๐
This is a common point of confusion when working with lists in Workato.
Instead of creating a list using the โCreate Variableโ step, you actually need to use the โCreate Listโ action from the Variables by Workato. This is an important distinction because:
The "Create Variable" step does not support iteration in a repeat loop. (For this iteration process we need to parse the Variable output).
Only a list created using "Create List" can be added to using "Add item to list" and we can iterate overusing a "Repeat Action".
Use the "Create list" action --> Need to create a "TasksDueThisWeek" list with the payload structure mentioned by you.
Let me know if it works to you โ happy to help further! ๐
