โ08-13-2025 02:15 AM
Recently we've encountered strange Workato behavior. In a loop, we're calling recipe functions asynchronously, store the job references in a list and outside of the loop we pass that list to the "Wait for async calls to complete" action. We want the recipe to wait for all the child jobs to complete and continue parent processing when all finished.
The weird behavior is that even when all the jobs completed, the parent recipe job is stuck in processing state:
Here's the implementation in the parent process:
What's even more interesting is that if we set the timeout limit to e.g. 1min (line in example) and wait it out, the parent process is still stuck in processing. Here's the screenshot from yesterday right after I canceled the execution (look at the duration time):
That's definitely a 1min timeout not working.
Does anyone had similar issues and came up with a solution for that?
โ08-13-2025 02:43 AM
Hi @dawidleman,
I guess you are running the recipe using a test job, right?
Could you please try starting the recipe in normal mode (not in test mode) and check it again? Let me know if you still face the same issue after that.
Thank you...!
Hi @dawidleman,
Thank you...!
โ08-13-2025 04:02 AM
Indeed, I was testing it with test job. Activating the recipe and waiting for normal mode helped - now it's running properly.
Any reason why it's not working in a test mode?
โ08-13-2025 04:19 AM
Yes, because waiting actions are long actions in Worakto, where those will not work in Test Mode, like Scheduler in action step, SQL Transformations by workato, etc., those will not work in TEST MODE.
a month ago
Having a Question, Lets say if i repeat last Job which was run as Scheduler, will this new repat job will also run in same way it used to run during Scheduler run or will their be any limitations like while using wait, long running Queries etc.
