Workato - What’s trending at Workato? - May 24th 2024
estefania-romo
What's new?
IF … ELSE IF… ELSE IF… ELSE IF… ELSE…
You're going to live this one, as many of you were waiting for this!
We're happy to announce the enhancement of our conditional control statement.
What’s new
Now there is one conditional step “IF condition” instead of confusing two
Users can add or remove else if or else conditions to existing if condition at any moment of time without need to recreate the conditional logic (as it was before)
Users can reorder else if conditions inside single conditional block
How does it work?
Any conditional logic starts with IF, so users need to create the first logic block first
After first condition is added and users wants to add other conditions below, clicking “add step” will show panel will two more options: “ELSE IF” and “ELSE” that can be added to the previous conditional logic.
Check out the Web Documentation
Platform Ops latest releases
Here is a summary of the latest releases of features and enhancements for the Platform Ops product area.
We hope they improve the day to day work of our users on the system and reduce some manual work!
Let us know what you think
Time and date formats - New feature!
Now users can customize their settings to see the Workato platform in the date and time format they are used to work (and think) in - saving our users the time they spend on figuring out what those numbers on the screen mean 😆
New time and date formats are:
mm/dd/yy h:mm AM/PM
mm/dd/yy hh:mm
dd/mm/yy h:mm AM/PM
dd/mm/yy hh:mm
Check our Docs
Developer APIs
GET Job API - new fields were added for more visibility on the errors - error count, step, app, action, retry count
New API option to export and import! Now all you need is to provide a folder ID. If all assets are in the same folder then no more IDs for each asset you want to add to the manifest
Create and Update recipe API - new field to update recipe description
API collections & endpoint
A fresh look to the collections page and endpoint cards, featuring new icons to easily distinguish API recipe and API proxy endpoints.
(The most exciting part –) Recipe endpoints – you can now see the API request & response schema, recipe actions, key endpoint configuration immediately, once you click into an endpoint.
Previously, users would have to navigate to the recipe in order to see this.
Endpoint settings
We've created a new 'endpoint settings' tab – this allows users to have a persistent view of key endpoint configuration settings, without having to navigate into the 'edit endpoint' pop-up.
Note: this is a temporary state – we'll be adding more capabilities to the settings page as part of our API proxy transformation project.
UI enhancements
Job history page - due to performance issues and long loading times in some cases we introduced a new default for the time filter, it is now set for "last 30 days" by default, improving the experience working on this page especially for heavy recipes.
Deployments tab - more time filters are now available enabling users to see deployments history older than the last 30 days.
Some fixes
Notification emails - we added the workspace name (the correct one 😆) to the notification alerts users get from Workato, for them to easily recognize the relevant workspace
Scheduler - during Jan-Feb we did some improvements to the timezone logic of the scheduler (it had some bugs) as part of the fix we also set the timezone as a mandatory field. This has been fixed back to being an optional field due to the requests from the field
ALR - Preventing customers from selecting wrong configurations
Coming up soon:
Job history table download
Manifest page UI improvements
LUT page UI improvements -
Improved assets search - text search will search also through the description, apps, actions
image (63).pngCheck out the Web Documentation
Field Connectivity Team Updates
Here are the latest community connectors and recipe updates!
What’s new on Product Hub:
Recipe Highlight:
New/Updated Connectors:
AWS Bedrock
Kintone
iChris (Static)
JobAdder
Camplife
Aimtec ClouEDI
JD Edwards
Backlog
MYOB Advanced
Acumatica
SugarCRM
Harvest
Workato Embedded
Freshsales
ClickUp
Amazon Kinesis
Freshservice
HiBob
Sage Intacct (Custom)
Personio
GraphQL
 image (64).pngCheck out our Product Hub
0 REPLIES 0
