Call an API to multiple tables in a Single Job
lalatendujena
I want to call multiple GET APIs from my recipe. In Step 6, I am currently calling one GET API, but I need to retrieve data from multiple data stores using the same step/API. Essentially, I want to pass the name of the data store (API endpoint) at runtime.
Let's say I have the API like this -> xyz.com/api/data/DatastoreTable1
So in runtime it can be DatastoreTable1, DatastoreTable2, DatastoreTable3...
I created a variable for this purpose, but it did not work.
Appreciate any assistance.
2 ACCEPTED SOLUTIONS
Hello @lalatendujena ,
In order to access the variable as a list in the for loop, it should be created in the way shown in the below images.
However, my suggestion would be to use a lookup or datatable, as that will be easier and more maintainable. If we go with a variable approach, then all the Request URLs need to be added to a list and accessed inside the loop, which can be a bit of a hassle.
  • If you already have the list, it will be easy to pass it at runtime.
  • If the list is not already available, creating and maintaining it using variables can be a hassle.
  • A separate list/loop again is required to add and store all those Request URLs.
  • If any endpoint needs to be updated in the future, it has to be changed at the recipe level.
  • Updating endpoints directly in the recipe is not a good practice and can be difficult to maintain.
according to me keeping all the endpoints in another location (like a lookup or datatable) and retrieving them when needed would be a better and more manageable approach.
francbaviello
Hi @lalatendujena , you can create a list with a specific schema and a fixed list of items "DataTable1, DataTable2...". You can see the correct solution:
โ€ƒ
8 REPLIES 8
Bhagya_pola
The simple and easy suggestion to implement would be, storing all these records either into a lookup or data table (better lookup ๐Ÿ™‚ ) and retrieve those entries in recipe.
Let me know if this approach doesn't work for you or need a better approach.
Thank you @Bhagya_pola for this,
Using a lookup table or a data table was my initial thought, but I preferred to use a variable where I could simply create a list of strings to solve my problem. Since I only need to pass the table names dynamically in the API URL at runtime, I thought this approach would be simpler.
However, I ran into an issue with mapping the variable. Iโ€™m not sure which datapills to map from the available options (from a for loop), and thatโ€™s where I got stuck.
Thank you @Bhagya_pola ,
These details make sense to me. I can use the data table for this case and will complete the required mapping. I will let you know if I face any issues.
I appreciate your assistance.
