Issue with Authentication Setup for Proxy API Access in Workato
Deena
Hello Workato Community,
I’m working with a Proxy API in Workato and encountering challenges related to authentication configuration.
  • I created an HTTP connection for the Proxy API and provided the username, password, and base URL.
  • My API endpoint requires three pieces of authentication: a username, password, and API key. However, Workato’s Proxy API only allows me to select one authentication type (Basic, None, Header, or Query).
  • Since I can only choose one authentication type, I’m unable to add both the username/password and API key in a single request. This limitation is causing the API call to fail with an "Access to this API has been disallowed" error.
  • I also tried including the API key as a parameter in the endpoint URL itself, but I still receive the same "Access to this API has been disallowed" error.
Could anyone suggest a workaround or method to include multiple authentication components (username, password, and API key) in a Proxy API call within Workato?
Additionally, any tips on how to effectively include the API key in a way that the endpoint will recognize and accept would be appreciated.
Thank you in advance for any guidance!
Hi @Deena,
May I know which API[Application] you are trying to connect to.
If the issue is resolved, what steps did you perform.
Hi @Deena,
did you try passing including the API key as a header parameter ?  Please let me know if you need further help Proxy method.PNG
Shivakumar K A
