Convert list of string to list of numbers
shefali
I/P is ["1","100","50", "4"]
O/P [1,100,50,4]
Hi @shefali,
1๏ธโƒฃ In the 2nd and 3rd images,
2๏ธโƒฃ I have a small curiosity: Why do we need to create two variables with Integer or Number data types to parse a number list?
3๏ธโƒฃ However, when using list functions, it still treats the variable as a list. Shouldn't it actually be recognized as a number instead?
Could you please share a screenshot? I didnโ€™t fully understand your point here.
Looking forward to your insights! ๐Ÿ˜Š
Shivakumar K A
21 REPLIES 21
Hi Shivakumara,
Thanks for the response. The function you've used appears to return a string variable containing integers. However, I need to first extract a list of integers. Then, I can use existing list functions to determine the minimum and maximum values from the list.
I am able to perform this operation on a list of numeric strings. However, the issue is that the min and max functions are returning values based on ASCII character order rather than numerical values.
If you feel there is an alternate way to handle this using existing functions, please guide me
Hi @shefali ,
I found another way doing it is
1. when the input is "List of String" pass it to another variable where it should of data type "Integer"
2. Workato will take care of your "List_of_String" to "List_of_Integer"
3. Apply formulae "MAX" or "MIN" whichever you needed as per your requirement
Here are some screenshots for your reference:
Thanks @shivakumara
Happy to help.  @Prudvi  ๐Ÿค—
HI Shiva,
I tried passing a list of string to a new variable of type integer. O/P is still a list of string. The auto -conversion is not working for me.
