Convert list of string to list of numbers
shefali
I/P is ["1","100","50", "4"]
O/P [1,100,50,4]
Hi @shefali,
1️⃣ In the 2nd and 3rd images,
2️⃣ I have a small curiosity: Why do we need to create two variables with Integer or Number data types to parse a number list?
3️⃣ However, when using list functions, it still treats the variable as a list. Shouldn't it actually be recognized as a number instead?
Could you please share a screenshot? I didn’t fully understand your point here.
Looking forward to your insights! 😊
Shivakumar K A
20 REPLIES 20
Hi @shefali,
Can you check this schema
"control_type": "text",
"label": "list_num",
"parse_output": "integer_conversion",
"name": "list_num",
"type": "integer",
"of": "integer",
"optional": true,
"details": {
"real_name": "list_num"
"initially_expanded": true,
"hint": "Defaults to nil if not supplied.",
"sticky": true
Hi Prudvi,
I tried updating my int variable schema exactly like yours. Still, the auto-conversion from List String to List Num is not working. Here is my update schema for reference " -
    "label": "v_tempInt",
    "name": "v_tempInt",
    "type": "integer",
    "of": "integer",
    "optional": true,
    "details": {
      "real_name": "v_tempInt"
    "sticky": true
Hi @shefali,
This is the schema of previous step  variable
"name": "list_str",
"type": "array",
"of": "string",
"label": "list_str",
"optional": true,
"details": {
"real_name": "num"
"sticky": true
Hi Prudvi,
I tried updating the source List String schema as yours. Still no luck. Here is a snippet schema code. Please let me know if you guys need any more info from me to debug this issue.
    "label": "v_StringTemp",
    "name": "v_StringTemp",
    "type": "array",
     "of": "string",
    "optional": true,
    "details": {
      "real_name": "v_StringTemp"
    "sticky": true
Hi @shefali,
is it possible to share the JSON which you are passing to the variable.
