02-27-2025 12:49 AM
I/P is ["1","100","50", "4"]
O/P [1,100,50,4]
03-02-2025 06:09 AM
Hi @shefali,
1️⃣ In the 2nd and 3rd images,
2️⃣ I have a small curiosity: Why do we need to create two variables with Integer or Number data types to parse a number list?
3️⃣ However, when using list functions, it still treats the variable as a list. Shouldn't it actually be recognized as a number instead?
Could you please share a screenshot? I didn’t fully understand your point here.
Looking forward to your insights! 😊
Shivakumar K A
02-28-2025 06:06 AM
Hi Prudvi,
Here is my sample JSON that needs to be parsed. I am first parsing the given JSON. Then, I use TestValueSampleList.pluck("v") to extract a list of strings, which I then convert into a list of integers using native functions and formulas.
"TestValueSample": [
"k1": "t1",
"v": "9"
"k1": "t2",
"v": "11"
"k1": "t3",
"v": "21"
"k1": "t4",
"v": "7"
03-01-2025 08:27 AM
Hi @shefali ,
Here, I am adding a screenshot after parsing the provided JSON.
- 2nd Image: The input hasn’t been explicitly converted to an integer, yet the output is a list of integers.
- 4th Image: If this doesn't work on your end, you can use another variable of type "Integer" and pass the output from the `pluck("v")` formula.
Shivakumar
03-02-2025 04:00 AM
Thanks, Shiva! Your solution worked perfectly for me—I really appreciate it.
I do have a small curiosity: Why do we need to create two variables of integer or number data type to parse a number list? For example, after the JSON parse step, I attempted to create a list of numbers, and the output appeared as expected—a list of numbers. However, when using list functions, it still treats the variable as a list. Shouldn't it actually be recognized as a number instead?
Is this the expected behavior of the function, or could it be a bug? It feels a bit misleading and requires a lot of trial and error to get right
03-02-2025 06:09 AM
Hi @shefali,
Shivakumar K A
03-02-2025 06:23 AM
Hi Shiva,
Sure. My previous comment was about whether it's possible to apply pluck and min on the same list. For example: TestSample.pluck('v').min(). Currently, this operation works based on ASCII character calculation when applied to strings. To get the maximum integer value, we first need to create a list of strings/integers and then use a variable of type integer to extract the maximum value.
Thanks for your help anyway. Appreciate it
That was the reason for my question. We can mark this as resolved if there’s no way to apply pluck and max on integers in the same step.
