Epicor Object condition with multiple values
AC
Hi Community,
For a while Im designing recipe and have a quick question. With epicor connector, once i want to filter a table with multiple values , It does not bring any result. My values ABC,DEF, GHI. Once I put these values in condition section with contains, No result. Such combinations I tried are following [ABC,DEF,GHI] or "ABC,DEF,GHI"
4 REPLIES 4
pavan-narayan
Hi @AC ,
Can you share the condition how you are passing that in the formula mode ?
AC
Hi @pavan-narayan ,
This is my case > Field From list : FieldA , Oeprator : Contains , Value : ['ABC','DEF','HIJ'] also tried 'ABC','DEF','HIJ' and similar combinations
pavan-narayan
If possible can you paste the screenshot here ..I guess we are missing something here...
We have the method includes in formula mode which returns boolean result , but no method contains in formula mode.
Thanks!
In Value part, I m trying to pass multiple values but does not work. Capture.PNG
I hope it helps the below screenshot
