a month ago
Hello,
The payload I am getting as a response is -
Message: "<div class="zd-comment" dir="auto"><span style="opacity: 1;"><img src="https://cybergrants1720708638.zendesk.com/attachments/token/TbvvjGtyhrIe3xX29VG3gQtQT/?name=image.png"><img src="https://cybergrants1720708638.zendesk.com/attachments/token/Ch1NuHKgwfEDSLKF4C3wWGaSh/?name=image.png"></span><br></div>"
I extracted all the HTTPs urls from the above payload and stored them in a string variable 'attachment_ur_ls'. I printed the variable value and it is showing -
"attachment_ur_ls": [
"https://cybergrants1720708638.zendesk.com/attachments/token/TbvvjGtyhrIe3xX29VG3gQtQT/?name=image.png",
Now I want to iterate through each of the link present in the above variable. I used a Repeat for each but unable to select the above variable inside Input list field.
The attachment_ur_ls looks like an array of string, and I want to iterate through each link present inside the variable and take actions accordingly.
Please help me in fixing this, it's on priority!
4 weeks ago
No Response so I will take a shot at it:
To fix this:
1. Make sure `attachment_ur_ls` is an actual array and not a string. If it's a string, parse it first (e.g., `JSON.parse()`).
2. Pass the variable `attachment_ur_ls` directly into the "Repeat for each" loop.
3. Test with a dummy array like `["url1", "url2"]` to ensure the loop works.
If this still doesn’t work, check if the variable is properly scoped or formatted for the loop to recognize it.
