โ12-08-2025 02:23 AM
I am trying to create openair connection in Workato using the OpenAir username and password, API key. But getting 500 internal server error.
โ12-16-2025 06:57 AM - edited โ12-16-2025 07:00 AM
HI @Madhusekharnaid ,
OpenAI doesnโt support logging in with a username and password. When creating an OpenAI connection in Workato, you should use only an API key (Bearer token).
If the connection is configured with a username and password, it can lead to a 500 Internal Server Error, which is what youโre seeing.
How to resolve this:
Generate an API key from the OpenAI platform
Set up the Workato connection using API Key authentication
Leave the username and password fields blank
Make sure the request includes this header: Authorization: Bearer <your_openai_api_key>
To confirm everything is working, you can test the connection using:
Once the API key is configured correctly, the connection should work without any errors.
Himaja.T
