Not able to make openair connection in the workato
Madhusekharnaid
I am trying to create openair connection in Workato using the OpenAir username and password, API key. But getting 500 internal server error.
Himaja
HI @Madhusekharnaid ,
OpenAI doesnโ€™t support logging in with a username and password. When creating an OpenAI connection in Workato, you should use only an API key (Bearer token).
If the connection is configured with a username and password, it can lead to a 500 Internal Server Error, which is what youโ€™re seeing.
How to resolve this:
  • Generate an API key from the OpenAI platform
  • Set up the Workato connection using API Key authentication
  • Leave the username and password fields blank
  • Make sure the request includes this header: Authorization: Bearer <your_openai_api_key>
To confirm everything is working, you can test the connection using:
Once the API key is configured correctly, the connection should work without any errors.
Himaja.T
