โ01-29-2026 06:01 AM
I have a CSV table that contains both parent and child records.
I need to identify if a row is a child based on a specific value in the Name field.
The parent is also identified by a specific value in the Name field.
For each child record, I need to:
Find the relevant parent record within the same table
Update the child rowโs ParentId field with the value of the corresponding parent
I am looking for an efficient and clear way to implement this logic in Workato.
โ01-29-2026 07:32 AM
Hi @shaked,
you can implement with the help of SQL Transformations by Workato application by passing CSV File contents or a file from FileStorage and implement the logic in SQL Query, where you can get the required output rows in a single step. Hope you got my point?
โ01-30-2026 12:06 AM
Thank you for your response,
Iโm relatively new to Workato and wanted to make sure Iโm following best practices.
In your opinion, would using a Lookup Table be the right approach here for mapping parent and child accounts, instead of using SQL?
โ01-30-2026 08:16 AM
Hi, the solution @rajeshjanapati 's is ok because:
Lookup table: Not suitable for large volumes, No complex queries, No relationships
SQL Collection: You have many records, Advanced SQL queries, You need to make complex queries
โ01-31-2026 08:36 AM
Thank you for the explanation.
Since Iโm still new to Workato, I wanted to get your guidance.
In my case, the CSV file is relatively small and contains a limited number of records.
Given this context, would a Lookup Table be a reasonable approach here, or would you still recommend using SQL Collections as a best practice?
Iโd appreciate your perspective.
