XSLT does not honor the output element
iyerha
I am using XML tools by workato and the Transform using XSLT action.
I am converting an XML input to a text output. I do this using the following XSLT element:
<xsl:output method="text" encoding="UTF-8"/>
But workato always seems to add the XML prolog to the output i.e. I get <?xml version="1.0" encoding="UTF-8"?> prefixed to the output.
This works correctly when I use another XSLT testing tool. Is this a bug? Is there a workaround?
Thanks,
Hari
Hi @iyerha,
Here are the small changes:
Your changes:
<xsl:output method="text" omit-xml-declaration="yes" encoding="UTF-8"/>
Changes required:
<xsl:output method="text" indent="no"/>
Shivakumara K A
