Join us as we explore the SQL Transformations Connector! See how it enables you to modify, augment, and handle data directly within your Workato recipes, optimizing workflows, cutting down on manual tasks, and driving powerful automation across your business.
The SQL Transformations Connector enables you to execute SQL queries and transform your recipe data, all without needing a database! With SQL Transformations, you can process complex datasets, perform calculations, and prepare data for downstream apps, making your recipes more powerful and flexible.
1. Detect Data Deltas and Change Data Capture (SQL Transformations, On-prem Files, and Amazon S3)
What it does:
- Identify changes in data across sources
- Automate data synchronization
Learn More: CDC - Fetch data extract from source, compare with historical data to find the delta, and stream it ...
2. Pipeline Multi-Source Data Enrichment and Transformation (SQL Transformations, Salesforce, and SFTP)
What it does:
- Combine and enrich data from multiple platforms
- Standardize data for analytics or reporting
Learn More: ETL - Extract opportunities from Salesforce, enrich with product price details, and load to destinat...
3. Extract, Validate, and Cleanse Bulk Leads (SQL Transformations and Marketo)
What it does:
- Cleanse and validate large datasets before import
- Ensure data quality for marketing operations
Learn More: Validation & Cleansing data - Cleanse leads before adding them to Marketo
4. Automate Data Quality Checks (SQL Transformations and Workato File Storage)
What it does:
- Run automated checks for missing or invalid data
- Trigger alerts for error
Learn More: 01 - Fetch daily orders for Point-of-Sale (POS)
Learn More:
Recipes to Get Started:
Q: Do I need a database to use SQL Transformations?
A: Not at all! SQL Transformations works directly on your recipe data in memory, so no external database is required.
Q: What SQL functions are supported?
A: The connector supports standard SQL operations including SELECT, WHERE, JOIN, GROUP BY, and common functions like SUM, COUNT, and CONCAT. Check Workato's documentation for the complete list.
Q: Can I combine data from multiple apps?
A: Absolutely! You can join and merge data from different sources within a single recipe, making it perfect for cross-system reporting and data enrichment.
Q: Any tips for optimizing SQL Transformations?
A: Start with small datasets to test your queries, use clear column names, and leverage SQL functions for calculations and data reshaping. Always validate results before sending data downstream.
Weโd love to learn more about your experience with SQL Transformations connector. What use cases have you tried, what worked well, and what tips or challenges can you share with the community?
๐ We will be randomly choosing one comment on this post to win exclusive Workato swag! Donโt miss your chance, share your thoughts or questions below!
Read more:
Letโs get the discussion started! ๐
3 weeks ago
thanks for sharing
3 weeks ago
SQL Transformations is a powerful in-house Workato utility designed to perform high-volume and complex data transformations using standard SQL queries. It allows you to process, clean, enrich, and merge data coming from multiple sources with exceptional speed and efficiency.
Multi-source querying:
You can query and combine data coming from any number of data sources, making it ideal for integration scenarios involving multiple systems.
No volume limitations:
SQL Transformations can fetch, process, and output extremely large data setsโhandling millions of records without performance issues.
High performance:
The engine is optimized to run SQL queries and generate output datasets in just seconds, even when working with complex logic.
Support for advanced SQL operations:
You can use complex SQL SELECT statements, joins, aggregations, and additional SQL functions to reshape data according to your business needs.
This feature enables you to execute database-style transformations directly within Workato, without relying on external data warehouses or writing long code-based transformations. It simplifies large data handling and provides a familiar SQL interface for building powerful data workflows.
Hi @dianest ,
SQL Transformations in Workato allow you to run SQL queries directly on your recipe data without needing a database.
It helps you transform, filter, join, aggregate, and reshape data inside your recipe before passing it to another system.
You can handle thousands of rows easilyโclean, filter, or restructure the data.
Useful for integrations involving heavy field mappings (e.g., IDocs, XML, JSON).
Combine data coming from Salesforce, SAP, files, APIs, etc.
Use SELECT, WHERE, GROUP BY, JOIN, SUM, COUNT, CONCAT, and many more functions.
Instead of looping row by row, SQL can process everything at onceโmuch faster.
Clean and structure data before sending it to systems like SAP, Marketo, NetSuite, Snowflake, SFTP, etc.
Hello @dianest
SQL Transformations worked really well for my use case. I had to run a purging process every 90 days and generate a file with all those records. Since the data runs into thousands of rows, Data table operations didnโt fit because of the 1000 record limit.
Using SQL Transformations, I could generate a full CSV content in one single step though the processing time is a bit high, but the convenience is totally worth it.
The only part I couldnโt handle using SQL Transformations was the delete, so I used SQL collections for that. Overall, itโs a great option for bulk data handling.
