โ11-14-2025 09:55 AM - edited โ11-14-2025 09:56 AM
Join us as we explore the SQL Transformations Connector! See how it enables you to modify, augment, and handle data directly within your Workato recipes, optimizing workflows, cutting down on manual tasks, and driving powerful automation across your business.
The SQL Transformations Connector enables you to execute SQL queries and transform your recipe data, all without needing a database! With SQL Transformations, you can process complex datasets, perform calculations, and prepare data for downstream apps, making your recipes more powerful and flexible.
1. Detect Data Deltas and Change Data Capture (SQL Transformations, On-prem Files, and Amazon S3)
What it does:
- Identify changes in data across sources
- Automate data synchronization
Learn More: CDC - Fetch data extract from source, compare with historical data to find the delta, and stream it ...
2. Pipeline Multi-Source Data Enrichment and Transformation (SQL Transformations, Salesforce, and SFTP)
What it does:
- Combine and enrich data from multiple platforms
- Standardize data for analytics or reporting
Learn More: ETL - Extract opportunities from Salesforce, enrich with product price details, and load to destinat...
3. Extract, Validate, and Cleanse Bulk Leads (SQL Transformations and Marketo)
What it does:
- Cleanse and validate large datasets before import
- Ensure data quality for marketing operations
Learn More: Validation & Cleansing data - Cleanse leads before adding them to Marketo
4. Automate Data Quality Checks (SQL Transformations and Workato File Storage)
What it does:
- Run automated checks for missing or invalid data
- Trigger alerts for error
Learn More: 01 - Fetch daily orders for Point-of-Sale (POS)
Learn More:
Recipes to Get Started:
Q: Do I need a database to use SQL Transformations?
A: Not at all! SQL Transformations works directly on your recipe data in memory, so no external database is required.
Q: What SQL functions are supported?
A: The connector supports standard SQL operations including SELECT, WHERE, JOIN, GROUP BY, and common functions like SUM, COUNT, and CONCAT. Check Workato's documentation for the complete list.
Q: Can I combine data from multiple apps?
A: Absolutely! You can join and merge data from different sources within a single recipe, making it perfect for cross-system reporting and data enrichment.
Q: Any tips for optimizing SQL Transformations?
A: Start with small datasets to test your queries, use clear column names, and leverage SQL functions for calculations and data reshaping. Always validate results before sending data downstream.
Weโd love to learn more about your experience with SQL Transformations connector. What use cases have you tried, what worked well, and what tips or challenges can you share with the community?
๐ We will be randomly choosing one comment on this post to win exclusive Workato swag! Donโt miss your chance, share your thoughts or questions below!
Read more:
Letโs get the discussion started! ๐
โ11-16-2025 10:16 PM - edited โ11-16-2025 10:17 PM
Hi @dianest ,
Thankyou for sharing these monthly deep-dives on new Workato features, itโs a great initiative and truly helpful for the community.
Regarding SQL Transformations in Workato, here are some key highlights based on my experience:
A powerful ETL/ELT engine โ๏ธ
Enables seamless transformation of bulk datasets directly within Workato recipes without relying on external databases.
No storage limitations ๐ฆโจ
Since SQL Transformations run fully in-memory, you are not constrained by traditional database storage restrictions.
Support for file-based data ๐๐
A unique capability to include files (CSV, Excel, etc.) as part of rows during transformations, an excellent add-on feature.
Advanced data cleansing & quality operations ๐งน๐
Ability to filter, cleanse, deduplicate, validate, and normalize large datasets efficiently. You can also remove or transform specific fields as needed.
Connect multiple data sources effortlessly ๐๐
Supports combining data from Workato Data Tables, Workato FileStorage, Content Streams, and various app connectors.
Join & compare cross-source data ๐๐
Ability to join or compare datasets from different sources, for example, matching FileStorage data with Data Tables, all within a single SQL query.
Improves recipe and task efficiency ๐๐
Offloading complex logic into SQL Transformations helps optimize recipes, reduce task consumption, and simplify overall workflows.
Easy Excel โ CSV conversions ๐๐๐
SQL Transformations makes it very simple to convert Excel files to CSV and vice-versa, something that is more complex when using only native Workato actions.
Overall, SQL Transformations is one of the most powerful additions to the Workato platform for heavy data processing and cross-system data preparation.
Thanks & Regards,
J Rajesh Kumar.
โ11-17-2025 03:27 AM
Hi @dianest ,
SQL Transformations is easily one of the most impactful additions to Workato.
It brings true SQL power into your recipes, simplifies complex integrations, and handles large volumes with ease.
If you work with large data, complex mappings, or multi-source integrations โ SQL Transformations is a must-use tool.
โ11-17-2025 06:33 AM
Hi @dianest ,
Thank you for bringing new deep dives post.
Here are my thoughts with few examples
In-Memory ETL/ELT Engine
Perform complex transformations without external databases or infrastructure.
No Storage Constraints
Fully in-memory execution ensures scalability for large datasets.
File-Based Data Handling
Merge CSV, Excel, and other file formats with app data seamlessly.
Data Quality Enhancements
Deduplicate, validate, normalize, and cleanse data at scale.
Multi-Source Integration
Combine data from:
Cross-Source Joins & Comparisons
Example: Match Salesforce Opportunities with CSV-based campaign data.
Recipe Optimization
Offload heavy logic to SQL, reducing task usage and improving speed.
Dynamic Schema Handling
Automatically adapts to schema changes, minimizing maintenance.
Built-In Analytics
Perform aggregations (SUM, AVG, COUNT) and grouping directly in SQL.
Conditional Transformations
Apply business rules dynamically (e.g., region-based filtering).
Data Enrichment
Add calculated fields like revenue projections or performance scores.
Error Handling & Validation
Flag invalid rows and route them for review before final output.
Format Conversions
Effortless Excel โ CSV conversions without complex steps.
Scenario:
Quarterly report combining Salesforce Opportunities and Marketing Campaign data.
Solution Steps:
Impact:
Use Case:
Convert multiple Excel sheets into a single normalized CSV for ingestion into Snowflake.
Shivakumara K A
