Browser crashing when editing recipe
jmcvicker
Sometimes I have a recipe that crashes my browser every time I try to edit it - sometimes even if I try to just look at the recipe (without editing). It's not all recipes, or even all recipes with a specific connector, as far as I can tell. Console is logging this error multiple times: "Could not load content for https://app.workato.com/sourcemaps/6032.148888e41c6bff0b.js.map: HTTP error: Status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE". Anyone else have this problem, and how can I prevent it?
Jen McVicker
CSP-SM, CSP-PO, SAFe 5 SPC, ICA-AC, ICA-ATF, Automation Pro II
16 REPLIES 16
jmcvicker
Also getting this error (last one that crops up): mixpanel-2.2.min.js:73 Cross-Origin Read Blocking (CORB) blocked cross-origin response https://api-js.mixpanel.com/track/?verbose=1&ip=1&_=1652887247147 with MIME type application/json. See https://www.chromestatus.com/feature/5629709824032768 for more details.
Jen McVicker
Hi Jen,
Can you please confirm which internet browser are you using ?
--Sai
Try following:
1. Update the Chrome to latest if it is not.
2. Try using the Chrome's Incognito mode (CTRL + SHIFT + N).
3. Try Firefox & it's incognito mode.
himanshu
Hello Jen,
Please also mention the browser make/version that you are using.
Does this also happens in case of different browser(s)?
Thank you.
